Can't change camera or video settings
ChrisN
Canberra
Hi
Problem?
New Mavic Pro, with iPhone 7, and the DJI Go 4 app installed and apparently working ok.
All updates installed as notified.
Controller and the app worked fine for a few short test flights today.
My problem is that I am not able to access the settings for either the camera or the video. In the app, I am able to switch between the camera and video modes using the icon just above the shutter release / video capture button on the left of the screen. However the "slider" icon below the shutter release button does not do anything.
Was unit in a crash? No
What have you tried so far? Swapped out of "Beginner Mode" - no difference.
What device are you using ( iphone , ipad, Samsung , etc)? iPhone 7
What firmware are you running ( aircraft, remote controller)? Not sure but should be up-to-date as this is brand new equipment.
What Go app version are you using? DJI Go 4 (fresh installation today)
Any modification?
(if so what) No
Did you change anything or install any apps? (if so what) No
Do you have a video or pictures of the problem? (if so post link)
No
Thanks
Problem has now gone away! Not sure how or why, but I now have access to the settings options for both still photos and video. :)
You must be connected to the drone. Drone on and RC on and linked.
aboveus
