- Joined
- Sep 10, 2018
- Messages
- 240
- Reactions
- 870
- Age
- 68
Great pics folks!
My thing is sunsets in hyperlapse. Give it a try for your sunrises.
Put your bird up, frame the shot as the capture area is slightly smaller than the screen an will show brackets at the corners, select the hyperlapse, then open settings in manual and adjust the Fstop until MM is about -3. Select the hyper lapse.... I find 2-5 seconds the best interval. Start the hyperlapse. I will then tap the icon to extend the clock until I have about4-5 min flight time left and start it. If it looks like it won’t have time to finish I just stop it early and it will process the hyperlapse as long as it’s got at least the initial shots finished.I'd like to try a sunset hyperlapse. Can you (maybe save me some trial and error time) and advise the best settings (shutter speed, etc) for a smooth hyperlapse like this one, or does the camera default to it's own settings after you choose the time between shots and the length of clip you want?
Thanks Gonna give it a tryPut your bird up, frame the shot as the capture area is slightly smaller than the screen an will show brackets at the corners, select the hyperlapse, then open settings in manual and adjust the Fstop until MM is about -3. Select the hyper lapse.... I find 2-5 seconds the best interval. Start the hyperlapse. I will then tap the icon to extend the clock until I have about4-5 min flight time left and start it. If it looks like it won’t have time to finish I just stop it early and it will process the hyperlapse as long as it’s got at least the initial shots finished.
Hope this helps
Yes it did. I'll be using it often now... Thank you again!Looks like it went well from your test results.
