Change from Meters to Miles...
tbw
Northern Nevada
Noticed when I go into my flight Data Center, the distance is shown in Meters. Is it possible to change from Meters to Miles? If so, please explain.
Reactions: Spartan Drones
No it’s either metres or feet
I will assume you are using an Android device.
Unfortunately, with the Androids, the unit here stays metric even if you select imperial in the aircraft control settings.
Funnily enough, on an ios device you can actually chose which units you want to display, metric or imperial.
Ben.p
