Just picked up the charging dome, or whatever it’s called, not necessary but pretty cool. For those of you that have it, do you leave the USB magnetic charging port in the drone or take it out every time. Worried what it may do to the weight
Did you find it hard to remove? worried it may do some damage.Just got mine today. Very cool for display and charging. Still thinking about this, your question. It weighs less than 1 gm and would help to protect the USB port on the MM. I have not found the need to use the MM USB port for charging as I charge my batteries with the brick. I also purchased another (4th) battery to add to my rotation, so one will be stored in the aircraft. I am not sure the magnet will interfer with flight operation. While it is a tight fit in the USB port, I would not want to lose it. The more I think about it, will probably not use it in flight, but keep it with the "dome".
Also, are you leaving one battery in the drone at all times? fully charged?Not hard to remove, but a tight fit to get a good grasp. If I was out in the field and found some reason (?) to take it out, I could see it flying out of "my" hands and lose it. About same difficulty/risk, if I had to remove the SD card. Y'know, fingers getting in the way.
it is recommended by DJI to remove it before flying ...Just picked up the charging dome, or whatever it’s called, not necessary but pretty cool. For those of you that have it, do you leave the USB magnetic charging port in the drone or take it out every time. Worried what it may do to the weight
Storage level is around 60% correct?you should not be storing batteries fully charged for any length of time, in any thing, its best just to charge them up the evening before you intend to fly if possible,,and then after use if you do not intend to fly for some time then charge them back up to storage level
according to the manual storage level is 39% to 75% so 60% would be fine,as has been mentioned, the MM batteries do not self discharge, DJI recommend discharging to storage level if not used after 10 daysStorage level is around 60% correct?
I agree. It is a strong magnet that attaches quite firmly to another magnet in the charging base. For me, it is better to keep it with the charging unit.I would not lave anything magnetic on the drone during flight ops.
I wish they made something similar for the Mavic Pro. This is a really cool idea for showing off your drone while charging.Here's an interesting link to the care and operation of the Mavic Mini Charging Dome..
Only 6 minutes, I found it very helpful. I am in no way affiliated with Drone Valley.
Sorry to hear that. I have had mine since they came out. Has been plugged in with no concerns. The dome power button is always on, drone light (top) only when displayed. You may have a defective one. Troubleshoot; try new power source, press power button on/off, find receipt. Others may wish to weigh in.I have this base and it stopped working after 2days
