Charging Mini2
I don't think so, they are completely different battery designs.
You'll just have to get the charging hub for the Mini 2
@Peshoa the USB on the MA2, is it what you use to charge the RC with ,if so then yes you can use it to charge the Mini2 battery,but it might take a while depending on its output rating
Thank you mate, these are good news, yes there are many other USB chargers, but I would like to use something serious and trusted...like DJIs one...
@Peshoa it should say the output of the USB on the back of the charger ,are you just charging one battery in the drone ,or do you have the flymore combo with the hub
No hub available, basic set. There si no charger in this set and that is why I am looking for good solution....and solved...
It will work but is not necessarily "solved" as it may affect the amount of time. The chargers are specifically designed for specific batteries. It would be worth your time to check the output of both chargers. While the voltage is the same, the current will affect how long it takes. Charging too rapidly can harm a battery. Charging too slowly can affect your patience.
@netfolks2000 ,hi friend he will not be using the main output of the charger for the flight batteries ,just the USB that is used to charge the RC i have already mentioned that this may take a while to charge due to its output,
Reactions: old man mavic
When using the drone to charge the battery, I use an Anker power adapter that supports USB-C PD. It's significantly faster than the standard DJI charger (supports charging up to 28W). Just about any USB-C PD adapter will do the same.
Augustars
