Cheap Joystick extender
TaiTony
Taiwan
Yestday received Mini while I already has AIR. Just install two F-type plug over Joystick, you can easy to use two finger to control the drone.
BTW, I test all QC3 chargers, it support quick charge at 9V to drone itself or charger.
The RC is fine to connect Flight Simulator.
Ideally AC should be using [email protected] which yields 18 watts when in QC.
In your configuration you're yielding about 15 watts. Not much of a difference though.
The charger that came with the Flymore is rated 18 watts via 12v.
Sorry this meter just support to 9V diaplay, my other one in central Taiwan may display 12V。
pier95
