Hello friends,
Last week I flew my Mini in the park on a sunny day with clear skies. Everything was fabulous until I lost VLOS with the drone, even if it was not far or too high. The Mini with its gray color does blend in very nice with the sky and you can just lose it. Long story short, at 100-120m distance and 45-60 m altitude the AC was invisible in the sky. I see the image on the screen, but cannot see the drone in the sky. By definition, this is loosing visual line of sight as it's in front of you but camouflaged.
I was thinking about how to overcome this in such a way that allows me to get this done cheap and fast. The only options I could come up to reuse so bicycle lights. Cheap would be about 10-20 USD. And fast means 1-3 days, not waiting for month for AliExpress or any gadget site. Third requirement is to be able to mount it on the mini without too many extras. Ideally would be to be able to snap it on off.
First option - use a butchered down LED position stop light. Butchered because I wished to get rid of every extra weight that was not needed. This leaves me with the electronics board with 3 light patterns (Solid, blink slow and blink fast) and the battery holder as these are powered by 2x CR2032 batteries. Total extra weight about 9 grams. This is applied on the mini with Double-Sided Adhesive Tape.
No pictures as it's just ugly.
Second option - rechargeable bicycle LED stop light. Assembled it has 15 grams. Can be hold in place by a rubber band. Total weight of the aircraft with this is 264 gram. The benefit if it's rechargeable, is that you just plug it in and it will be hassle free. Has 4 light patterns (3x blink + solid)
Third option - same bicycle light type but White, without the plastic enclosure. Stripped down it has a mere 5 grams. It can be attached to the mini via 2 rubber bands over the belly.
Forth option - combination between the second and the third. Red Tail light and while belly light. Total Aircraft weight is 269-270 grams.
It's currently dark outside, so I went out and tested it in the open. Is visible from below and when the aircraft is flying away from you. I've noticed that when it flies towards you, the tilt is hiding the lights in sports mode. This is the reason why a 3 or maybe a 4 light strobe combination might be visible from very angle.
Alternatives:
- connect all 4 electronic boards to a single battery. This would allow for visibility on each leg with maybe 10 grams total weight.
- add a white strobe in the front, etc.
I guess that you can extrapolate this and maybe find a cheap solution in your city.If you have any additional ideas please share them below.
Total cost was 60 ron (15 USD) for all 4 rechargeable bicycle lights. As for the type of those, I believe that they are these (SHENKEY-RED and maybe SHENKEY-WHITE)
Alternatives:
