Cire from central Texas
  • Thread starter Thread starter Deleted member 173459
  • Start date Start date
Hi from central Texas.
I just got a DJI Air 2S and it is simply amazing.
Does anyone know if Pedernales Falls or Enchanted Rock allow drones? Both would result in incredible footage.
Maybe look under T
exas Park Rules
Hi from central Texas and first time drone owner.
Welcome from Savannah, GA!!!
Welcome to our forum, from Hauptmann, in Hurst, Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro.
AFAIK drones are NOT allowed in any Texas State Park unless it has an AMA field within the park. Only two qualify: Whitney and another near San Angelo. Sorry!
We have over 150,000 members—many, many from your part of Texas--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have have already been addressed, and are easy to search. If you have NEW questions, just ask!
I attached a couple of links below, which will make learning piloting and photo/video skills easy.
Glad to have you with us!
Rich R (aka Hauptmann)
I just got a DJI Air 2S and it is simply amazing. Does anyone know if Pedernales Falls or Enchanted Rock allow drones? Both would result in incredible footage.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
One you've done your legal stuff, you need to learn you’re the Texas rules and laws concerning flying drone. To answer you questions about those locations, the answer is NO…
"Drones are not allowed in Texas State Parks without a permit except for in two parks with specified zones for flying remote-controlled aircraft (including drones): Lake Whitney and San Angelo. You can request a filming permit for your craft at any park by contacting that park."
Finally, since you live on a ranch, some of your neighbors may consider you flying over their property as "Trespassing" and shoot you down… Texas even tried to pass a law this law…
"You need permission to fly over private property. In general, it is illegal to use a drone to record or photograph others without their permission. The law makes an exception for using a drone in an emergency situation when there is an imminent threat to life or property"
Some police may actually enforce this illegal law… Beware...
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are still required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Fly On and Fly Safe…
Hello from Minnesota and welcome to the Forum....Congratulations on your Mavic Air 2s...There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safely and fly smartly representing all of us drone hobbyist well.
Welcome @CireTX from Brenham TX. I love flying my drone (Air 2S) over the ranchland around me, such beautiful vistas. Especially this time of year. We've finally had rain, so all the tanks & ponds are full, and everything is green! I need to post a pic or two in my welcome thread.
Nice pic of your ranch! What part of Central TX are you?
Thanks to all for the nice warm welcomes.
It has been a decent spring with the rainfall. Our tanks look good and our seasonal creek is flowing. I hope we get three cuts on our hayfield as last year we on had 1-1/2 and barely had enough for the cattle.
Liger210
