I’m still learning about magnetic interference. I was recently told that “magnetic interference while flying under bridges isn’t a concern. It only matters when calibrating the drone”. Is this true?
For calibrations, the compass calibration is the only calibration that can be negatively affected by nearby magnetic metal objects.Never calibrate compass, etc, when there is magnetic interference
Thanks for clarifying my concerned. ?No, it's not true. You want to keep the aircraft away from all magnetic metal objects while it's powered on. 10+ feet away should keep you safe.
Flying under a bridge could also cause the GPS signal to be lost. If that happens, the aircraft could drift sideways due to the switch to ATTI mode. When flying in ATTI mode, the aircraft will not be able to hold its horizontal position when it's too high for the sensors to "see" the ground below.I lost my Mavic in a River due to magnetic interference from a metal bridge. When I went under the compasses went nuts and it flew sideways all the sudden and crashed.
Thanks for sharing what was a painful and expensive loss. I know there are pilots flying under bridges but I suspect they have a horseshoe up their arse?? as a new pilot I question everything because there’s so much misinformation out there. Hope you get back in the air soon.I lost my Mavic in a River due to magnetic interference from a metal bridge. When I went under the compasses went nuts and it flew sideways all the sudden and crashed. Still havent saved enough to get another drone and its been a year. I literally cried, lol. Funnest thing i ever done was fly that stupid thing. Lol
Thank you. There’s so much misinformation on You Tube channels that I question much of what I hear. Thanks.Flying under a bridge could also cause the GPS signal to be lost. If that happens, the aircraft could drift sideways due to the switch to ATTI mode. When flying in ATTI mode, the aircraft will not be able to hold its horizontal position when it's too high for the sensors to "see" the ground below.
Flying over surfaces like water gives unpredictable results with the bottom positional sensors as well - as DJI makes clear in their instructions.Flying under a bridge could also cause the GPS signal to be lost. If that happens, the aircraft could drift sideways due to the switch to ATTI mode. When flying in ATTI mode, the aircraft will not be able to hold its horizontal position when it's too high for the sensors to "see" the ground below.
I bet it was the switch to Atti mode that did it, I never thought about that. I searched and searched that river, she was never seen again, lol.
