Thanks. You are confirming my inclination to go with the built in screen rather than the hassle of a phone for the screen. Just want to be sure the built in screen doesn’t come with compromises over using a phone.@neoflyer i have the built in screen RC s for both my Mini 3 pro and Air 3 ,and they do offer some advantages over having to use a seperate screen device
those are mainly ease of use, reasonable sized screen ,not affected by heat or cold causing dimming or shutting down
yes the screen brightness could be better in very bright sunlight ,but to aid with this i have covers that fit onto the RC ,that act as protection for leaving the sticks attached and also fold up to act as a sun shield as well
it is also advisable to have a lanyard attached to prevent it falling, if you have to let go of it for any reason ,and it saves the possibilty of the screen being damaged ,during such an event
@neoflyer well for some people, the fact that the RC uses Android ,can be a compromise ,especially if they are used to IOS ,and for others, that like to use aftermarket APPs ,then that can be an issue as well ,its really down to personal choice
