Will this controller work with both the Mini 2 and Air 2S? I am looking at a a all in one controller for both.
DJI Smart Controller https://a.co/d/9FgLGU6
which would be a problem if you didn't have an internet connection....correct?Yes but will need to be PAIRED each time you switch aircraft.
The internet connection is only needed if you want to undo bindings and make new bindings.which would be a problem if you didn't have an internet connection....correct?
The smart controller can be paired to only one aircraft at a time and that is what some say is a PIA. You add aircraft in AIRCREFT MANAGEMENT but if you change aircraft you MUST PAIR every time.The internet connection is only needed if you want to undo bindings and make new bindings.
Someone correct me if I am wrong but isn't it the idea that the smart controller will, once it has been linked to a drone, remembers that linking and, even if used with another drone in between times, it still remembers the linking and will automatically link to the drone when not actively linked to another controller.
Compatibity = DJI Smart Controller - DJI
Manual = https://dl.djicdn.com/downloads/smart controller/20210930/DJI_Smart_Controller_User_Manual_EN_202109.pdf
$819 is way too much money for that age controller. If you decide to upgrade your drone for example Mavic 3, Classic, Air 2S, Mini 3, or Mini 3 pro, you can not bind this drone with that controller except for the Air 2S.Will this controller work with both the Mini 2 and Air 2S? I am looking at a a all in one controller for both.
I'm not positive, but it looks like each time he switches drones, the controller reboots and it may be that part of the reboot requires an internet connectionThis is what I meant.
Protocol | 2.4GHZ | 5.8GHz | Max Transmission Bitrate | Latency (Depending On Environmental Conditions) |
FCC | ≤26 dBm | ≤26 dBm | 12mbps | 720p@30fps/1080@p30fps ≤ 120ms |
CE | ≤20 dBm | ≤14 dBm | 12mbps | 720p@30fps/1080@p30fps ≤ 120ms |
SRRC | ≤20 dBm | ≤26 dBm | 12mbps | 720p@30fps/1080@p30fps ≤ 120ms |
MIC | ≤20 dBm | 12mbps | 720p@30fps/1080@p30fps ≤ 120ms |
FCC | ≤ 31.5dBm | ≤ 31.5dBm | 50mbps | Low-Latency Mode: 810p/120fps ≤ 28ms High-Quality Mode: 810p/60fps ≤ 40ms |
CE | ≤20 dBm | ≤14 dBm | 50mbps | Low-Latency Mode: 810p/120fps ≤ 28ms High-Quality Mode: 810p/60fps ≤ 40ms |
SRRC | ≤20 dBm | ≤25.5 dBm | 50mbps | Low-Latency Mode: 810p/120fps ≤ 28ms High-Quality Mode: 810p/60fps ≤ 40ms |
MIC | ≤20 dBm | 50mbps | Low-Latency Mode: 810p/120fps ≤ 28ms High-Quality Mode: 810p/60fps ≤ 40ms |
