Found the solution:-after flying/recording(20 mins)if I put sd card from mm into a card reader on my iPhone often shows as damaged!!;;answer is to put card back into mm sync to controller and press recorded for 1-2 seconds;turn off and remove card;put back into iPhone and works every time;no issues(using photo fast one app and card reader)
I had a similar issue with a video file from my
Mavic 2 Pro recently. The file was on the SD Card, and both my iPad and Windows PC could see the file, but it had no file extension that either OS recognized, so it showed as corrupted. It also happened to be the last video that I had recorded that day, and this became a clue.
I too placed the SD Card back into the copter and booted it up. I waited about one minute, shut the copter down, removed the card, and the file was now recognized.
Since then, I have done a bit of reading here on the forum, and indeed, the copter's processor needs a bit of time to not only write the video data to the card, but it then applies the proper format to this file so it is viewable - or something like that in computer terms.
I am more of a photo guy, but if shooting video, I no longer land and quickly shut the copter off. I land and let it 'finalize' the last file it recorded for thirty seconds or so, and I have not had that issue since. That said, in order to recover these files - unless there is something different about the MM - the remote should not be required, and there should be no need to press record. The copter just needs more time to finalize the file.
