Crash and Gimbal seems to have a slow turnaround
BelugaOne
After the crash Ive tried to imu calibrated, compass and gimbal calibrate, the gimbal seems to work fine when facing forwards and down, but when you turn spin 360, it seems to very slowly get back to center and level out. Any ideas on a fix for this? Also the back tab under the gimbal, the little hook piece, is that suppose to press down on the anti shock bracket? or just sit above and stop it from moving further? Trying to avoid sending it back to dji, but if i have to.....
Honestly... I think this is normal. Mine, which I've never crashed does the same thing. I know exactly what you're talking about. If you whip it around the camera slowly and smoothly follows.
Wonder if firmware could cause this issue, going ti try and step it down, see what happens.
I may have fixed it. Went to the lowest firmware and ran gimbal calibration with an iphone. I heard that for what ever reason the iphone calibration works better. Did a quick test and the speed is greatly improved and the gibal is more accurate then ever. Ill post a vid when i can, and a proper flight test when it stops raning. But may have fixed it! :) We shall see..
Same problem, no crashes, many calibrations, no help! Must be firmware issue
Dispatcher
