Creating an Elliptical Waypoint Mission for Litchi
DJ Wes
Springdale, AR, USA
Site
www.litchiutilities.com
I have created another utility for Litchi waypoint missions. This utility is used to create a mission in the shape of an ellipse.
An ellipse may be defined by two foci and an eccentricity value. Google Earth Pro is used to provide the foci coordinates. Once converted to a Litchi waypoint mission, the foci are used as if they were POIs. However, once the mission is loaded into Litchi, those foci may be moved or deleted if so desired.
For those of you using drones including those in the Mavic 3 series, the Air 3, or the Mini 4 Pro, you are also able to use these Litchi utilities and then use my “Litchi Mission to DJI Waypoints” converter to fly missions on drones such as those.
Hallo ! Im happy with your mission creator !!! You are the best !
Is it possible to make the ellipse bigger or smaller ? I mean something like radius
venoom2001
