- Joined
- Jan 29, 2017
- Messages
- 28
- Reactions
- 13
- Age
- 77
DJI confirmed that CrystalSky monitor will not work with Mavic Pro 2. Apparently, they are working on a fix. Hopefully, soon or the monitor becomes a brick.
Wish I was. I tried on many occasions to get the Mavic Pro 2 to synch with the CrystalSky. After 5 calls to DJI and trying different solutions Joy told me that they are working on a solution and it should be coming soon.Um are you kidding? I use mine everyday with the Crystalsky...
It is fully compatible now, I don't know why they would tell you that, I use it every day with the M2P. You have to update the DJI GO 4 App (Not the Firmware, there isn't an updated firmware yet). To update start DJI GO 4 then go to "ME" at the bottom Scroll down to SETTINGS and hit "CHECK FOR UPDATE". The update has been available for a long time, you must have gotten a rookie tech support guy.DJI confirmed that CrystalSky monitor will not work with Mavic Pro 2. Apparently, they are working on a fix. Hopefully, soon or the monitor becomes a brick.
Check this video I did on the solution I like for mounting the CrystalSky to the M2P.That was true a month ago but now it works fine, but it’s been updated so no issue , I use Everyday . The one thing that is frustrating is that the Mavic Pro bracket won’t fit the Mavic 2 Pro without a modification. I bought the PolarPro but took it back due to a fault, it’s also heavy. Check out Fasttech , I am awaiting one if there’s to arrive
I have to have the quick release mount, I have it on my other 4 drones, that's why I went this route. It actually balances really well.Only issue with this setup is that it’s both bulky and heavy. The polar pro base for instance is really heavy. It also had a fault hence I returned it . I have also see someone modify the M2P controller so the existing bracket fits however I preferred not to do this. Check out Fasttech.com , I just got there’s for $18 , it gets the job done
!I have to have the quick release mount, I have it on my other 4 drones, that's why I went this route. It actually balances really well.
