CS mount for 2 controllers?
RickMz
(Cross-posting on PhantomPilots) Wondering if there is a CS screw-on mount that will allow me to move my 7.85 CS from the Phantom 4 Pro V2 mounting bracket (DJI, P/N DJCSP3RCM9, see attached) to a bracket compatible with my Mavic Pro. Conversely, is there a mount for the Mavic that will use the same screw-on bracket used on the P4P V2 CS mount? Trying to avoid having to screw/unscrew the bracket from the CS. Thanks for any light you can shed.........
If you using the DJI mounts, the adaptor plate that is fitted to the crystal sky is mechanically the same thing, just a different finish.
Mike, I'm not following but I suspect it's because I didn't explain what I meant clearly. Here is the bracket I use with my M2P, though they both attach the same way to the CS, the "problem" is how they attach to the rest of the assembly (the one below screws on). What I am looking for is for a piece (bracket/adapter/holder) that will allow me to move the CS from the P4 to the M2P without having to unscrew the bracket from the CS. Hope that's a little clearer. Thanks
Peteburns
