Custom foam for pelican case
Lapeer20m
Southeast Michigan
I spent the past few days trying to cut custom foam for mavic. I want to carry mavic with arms open and iPad inserted in the remote controller.
I'm a handy guy. I tried several methods but none look professional: hot wire foam cutter, electric turkey carving knife, scroll saw, and cnc machine with various router bits.
I tried room temperature, frozen, wet first then frozen,....
None of these methods makes what I would consider a desirable cut.
I found a local foam company that cuts foam with a cnc water jet. As long as the price is reasonable I will have them cut the foam. I already made an autocad file.
Reactions: Case K and optiplex
So I gave it one last try with the Hotwire and the results were pretty good.
I have to finish the 3D portion, but the cutouts worked quite nicely.
I first overplayed vinyl decals on the foam, then traced around that with the Hotwire.
The end result is rather nice.
I'll post photos after the finishing touches.
I bet it would work even better with denser foam, and foam that doesn't have all the perforations to facilitate picking it apart by hand.
It is amazing how small mavic and the controller are when folded compared to open.
Here is this new pelican compared to my original hard case: (this pelican is not for me, it's for work)
I definately recommend plasti-dipping foam. Especially this type as it is the pick/pluck type which makes it more fragile than ordinary foam.
Reactions: Ping^Spike
This is my pick and pluck first attempt. It works for now but I'm not sure how long it will last. This is a Pelican 1500 case.
Honestly it never occurred to me to try an unfolded configuration.
No I'm struggling to understand why you would either?! The mavic footprint unfolded isn't that much smaller than a P4P so why not just get one of those instead if portability isn't your primary reason for selecting a drone?? Just seems a while lot of messing around to carry a drone that is designed to be folded.
When you spray it over the foam it kinda sticks and melts the top layer of foam together.
It makes for a really nice finish over the surface and it looks like like one solid bit of foam after a few coats.
All the gaps between the pick and pull foam disappears
I never thought about plastidip, but I did make my own foam cutter for my firearms. I replaced the foam commonly sold it Pelican cases and replaced it with closed cell foam. Closed cell foam is way better than the foam commonly sold in Pelican style cases, it does not retain moisture.
Nice work... but... why store/ transport it spread eagle?
It's for a fire department. The idea is that mavic will be faster to deploy if it is unfolded and iPad is already in the controller and connected.
Also, it is less likely to get broken by some numbskull who is not that familiar with the device trying to fold it up incorrectly.
A phantom 4 standard doesn't have any significant advantages to mavic as far as flight characteristics or flight time.
The p4p does have a much nicer camera.
Mavic is a "practice" drone for the department to get familiar with while they plan and budget for a matrice 210.
CMDR DV TEARDROP
