DAT file on the aircraft
goixiz
is there a flight log file DAT on the aircraft / SD card...?
If it’s on aircraft - how do I extract the flight log or data file
Thank you
You can retrieve the DAT log from the Mavic like this.
Reactions: sar104
With the caveat that, under more recent firmware and hardware combinations, the aircraft DAT may not be accessible.
oh crapola - is there a specific firmware thats limiting this ??
Thank you
If you're running FW 01.03.0900 thru FW 01.04.0300 there could be a problem accessing the .DAT. Take a look at this
Keeping .DATs on the Mavic Pro accessible
As noted in that post if you're running FW 01.04.0400 or later you shouldn't have a problem.
elitewikipublishers
