I thought it would be a good idea to start a thread on repairs. this will help people with fixing their own Mavic
The guidelines for this thread are :
PLEASE DO NOT post questions asking what is wrong with yours! please use the mavic air help forum for that.
Please try to keep the same "format" when you post! for example : ( you may copy and paste this format)
Problem :
Troubleshooting techniques:
Parts that are need for the repair:
so for example the post would look like this:
Problem : front right motor not spinning ( as you are looking from it from the top view) of course remove all props
Troubleshooting techniques: I used a volt meter to measure voltage across motor. the reading was 8 volts which is to low. I also switch it with the front left motor ( for testing purpose) and it fire right up! The ESC circuit board is ok... motor was bad!
Parts that are need for the repair: replace whole front right arm assy which comes with the motor.
as for where to get parts at @Thunderdrones is approved vender I don't think he has a web site so you may want to shoot him a private msg
Problem :
