different FW Mavic-RC
#28
I have a brand new MP Platinum, After few flights I noticed the Mavic and RC has different firmware even if coming out from shop.
Aircraft: 01.04.0000
RC: 01.03.1000
I don't want to upgrade everything to the new fw (some friends claiming is better to stay on fw 01.04.0000).
1. Should be a problem having different firmware between aircraft and rc?
2. How should I upgrade only the RC to 01.04.0000? DJI Assistent 2 on my Pc is not seeing the RC (not sure I connect it in the right way). DJI Assistent on my Iphone SE is not seeing anything at all. DJI GO 4 app instead works perfectly (can you chose which fw use on the app?).
Thank you in advance.
Mismatched Firmware is common and many fly this way without adverse affects.
To install Assistant 2 properly one must turn off driver signature verification within the Operating System.
Thank you very much! Worked perfectly, I also had to use an other cable not from DJI..
jhgfdhjrye
