Disabled Pilot Question
Brahma
Scotland
Hello folks.
Thank you for letting me join the forum!
I’m looking at getting my first drone and am after some advice. I used to be a keen amateur photographer and spent many hours out with my camera taking landscapes and trying for some decent wildlife shots. Unfortunately this has come to an end following a back injury that means I’m pretty much housebound 24/7. I spend most of my day in my conservatory so have glass in 3 sides looking out onto my back garden and some local countryside. We have a dog that my wife walks everyday.
So my question: as I can’t walk my dog with my wife anymore, I’ve thought about using a drone from my conservatory and “following” my wife as she strolls around with our little beast. Would I be able to do this from the comfort of my easy chair? Or will I lose connectivity?
I don’t yet have a drone but am thinking of buying a DJI mini 3. Is this a good choice?
Many thanks,
The Mini 3 Pro is a good choice. You can use the zoom feature to capture wildlife without getting too close.
In my experience, glass doesn't cause much of any interference for the controller radio. For example, many people fly from the comfort of their cars in inclement weather. Trees and metal structures will prove more of a problem. If you maintain line of sight to the drone from your conservatory, you should be fine with any modern DJI drone.
Sympathies for your loss of mobility! We all take our mobile freedom and ability of movement for granted until we lose them.
If the UK rules are similar to the US, you can only pilot the drone if it is in your line of sight. In reality, that isn't very far and once the wife and pooch turns a corner, you will probably lose visual of the drone. However, your wife could pilot the drone and have it follow her and Fido, recording the whole venture for your viewing on their return.
As to the question of losing the signal, it too is pretty much line of sight, though it extends far beyond what the unaided human eye can see.
Mini 3 Pro would be a good choice since it has active track and can follow your wife as she walks. I think the M3P is the minibum with active track. Another consideration is that you'll want to launch the drone from outside the house so return to home won't put it on the roof. The opportunities for photography from the drone may prove to be a real benefit to you as it will open up opportunities you haven't had before. DJI is an excellent choice for a drone.
Thumbswayup :cool:
Hello folks.
Many thanks,
Welcome from the windy West Midlands of England.
Greetings from Chicago the Windy City, and welcome to the forum.
FLY SAFE & FLY SMART
I also sympathise for your loss of mobility, I have trouble walking, so I fly my drone from my car in the cold and in the heat. I had to experiment, to learn how to fly from inside a car. People are always looking for the pilot, where is he at?
Welcome to the forum @Brahma! :)
It really depends on whether or not you maintain VLOS the entire time. By that, I mean any obstacles that come between you and the drone could cause the signal to be lost. And then the drone would return back to the home point -- which could be problematic depending on where you take off (as noted above).
Any of the DJI consumer drones could do what you mentioned -- even more so if you were already comfortable flying DJI drones. You might struggle a bit learning how everything works if you're only able to fly inside. Being outside right next to the drone would give you a better feel for how it works and allow you to clearly see what's going on.
After flying many DJI consumer drones since 2016 (I own most all of them), here are some recommendations to help with whichever DJI drone you decide to buy:
  • Skip buying a non-DJI practice drone and start with any of the DJI consumer drones (ideally the model you'll be flying most). While it's true DJI makes one of the most expensive consumer drones, you likely won't learn much about your DJI drones by flying drones made by other manufacturers. And then you'll be back to square one again when you finally decide to ditch the practice drone and start flying a DJI drone.
  • Before attempting to fly, watch some videos on YouTube.com to learn more about your drone. Search for something like "Mini 2 Beginner's Guide" (replace "Mini 2" with your drone model).
  • Read the DJI manual (available in the "Products" section of the DJI Download Center) from beginning to end (maybe a few times). You're certainly not going to remember everything, but it'll give you a good understanding of the available features and capabilities of your drone. And then you can go back to the manual or YouTube videos when you need to take a deeper dive into a specific topic.
  • Don't power on your drone or take off when within about 20 feet of any magnetic metal objects (like your car or rebar in concrete sidewalks). See more on compass interference in this compass calibration guide.
  • Before taking off, always review the drone settings in DJI Fly (or the app you're using) to ensure everything is set as expected. If you do plan on flying near any obstacles, ensure the RTH altitude is set properly in case your drone needs to automatically return back to the home point mid-flight.
  • Never take off before DJI Fly (or the app you're using to fly) audibly mentions or shows the home point has been set. The drone will attempt to fly back to the home point location automatically if it loses connection with the remote controller, so it's crucial to ensure that location has been set prior to takeoff.
  • DJI drones have a lot of awesome automated flight features. Use them with caution and never assume they are always going to function as expected (always be ready to take control if needed).
  • Sensors are great and they can help prevent your drone from crashing into obstacles. They are not foolproof though. Never rely on them 100% or assume they are going to work perfectly in all flight conditions -- or react the same way when flying in similar conditions from past flights.
  • Find a flat, wide open place to practice (free of people, trees, and all other obstacles). It's pretty hard to crash a DJI drone into the ground, so you'll likely have the best success if that's your only obstacle. Continue flying in this location (or similar locations) until you're able to control your drone without thinking about it (like riding a bike).
  • Make sure you can easily see your drone at all times (required by law in most countries). After removing all nearby obstacles, nearly everyone who crashes/loses a drone is either not watching it with their eyes or cannot clearly see where it's located.
  • The screen is chock-full of great information. Use it as a reference (sparingly) as you do when looking at your dashboard while driving a car. It's also a great tool for framing the perfect photo or getting your drone in just the right spot before hitting record. If you're mostly staring at the screen while flying, you'll probably have no idea where your drone is located.
  • Don't fly in sport mode until you're comfortable controlling your drone. You don't want to get into a situation where you need to maneuver quickly and aren't quite sure which stick to move (another reason not to practice near obstacles).
  • DJI batteries require special care that is unlike other batteries you commonly use. To prevent any damage to your DJI batteries, follow the tips in this DJI battery maintenance & storage guide.
  • DJI drones record a lot of useful information in the TXT flights. The logs are helpful for things like troubleshooting issues you experienced during a flight, locating a lost drone, and many other things. The TXT files can be found on your phone/tablet or remote controller (if it has a screen). See these instructions for more details. And then you'll need a tool like my free online DJI log viewer or Flight Reader (keeps your flight logs offline) to decrypt and access/view the data within.
Hey pal!!
This is a great set of do’s & font’s for a beginner - thank you so much for taking the time to write all this down for me. I’ll take your advice and go straight for a DJI drone and learn on that from the off 👍👍
Since you live in Scotland, there are specific laws and rules for you to follow, please check to ensure these are current.
I will not get preachy about the legality of flying a drone from inside your home, where you cannot see the drone. But you should know…
But as has been mentioned, your location, inside a building, will be a hindrance to the signal strength, not only will the building interfere, but every tree, power pole, and the neighbor's homes will all serve to weaken the signal…
Not only will the intervening structures cause and issue, so will you… the antenna are directional and if you are facing the back yard while you wife is walking the dog down the street in front of your home, you are pointing the wrong way…
Good Drone Antenna signal and you will get a better idea of what I am writing about…
Next as has been mentioned, the drone needs to be launched from outside and in a clear area with no trees directly overhead, else if the drone does an uncommented Return to Home (due to signal loss), it could wind up landing in a tree if the landing location is not clear.
So, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
venoom2001
