Discovered something about Litchi today
Brojon
Texas
I started flying with Litchi and could not remember where the gimbal settings were.
So I switched to DJI Go4 and finished setting up the gimbal.
I went to look at the Airdata UAV data so I could number the new battery I flew with and - no data.
Tried it again - no luck.
Apparently if you start with Litchi but swap it out it never writes the data to Airdata.
For some reason I always assumed it was a continuous logging but it appears now that it is when the flight stops. I'm very curious how it knows that the flight is done. Perhaps start and stop motors.
Im guessing it logs from when the motors start to when it stops, if you start the motors in Litchi then swap it doesn't see the motor stop so won't log
It's not start motors, because I have missions started with DroneHarmony or DroneDeploy and then switched to Litchi while the aircraft was still in the air. Got the airdata flight logged from this point on.
Reactions: Brojon
So must be stop motors then. But there has to be something else to start collection because I've run multiple missions back to back and all the data is saved independently.
Humbug4
