DISH ARRAYI
Rchawks
Saint Joseph Mo
Would you be at all concerned about flying near such a area because of interference?IMG_1874.JPG
They look like they are mostly receivers, not transmitters. And if so, they would not cause you any interference… And even transmitters are not on your frequency… Is that a television station site?
Reactions: Rchawks and Cafguy
No problem flying Plus if you have a techy buddy, take them with you. Your buddy can probably hook you up with some free cable to watch while your batteries charge.
  • Haha
Reactions: Rchawks
Cable company.
Looks like the Optimum Cable site on North Woodbine. If so, then those dishes are mostly receivers for the 400 plus channels and Internet they provide… Of course, they might complain that the telemetry that your drone sends out (if flown just over the dish) might interfere with their reception… But you should have no other trouble…
Below is the Google Map, it's a bit old, it does not show the TV transmitter just north of this location…
This is the Airspace Map from my copy of the DroneUp App. The Red Arrow shows the Optimum Cable location, so if you are flying there, it's all Class G Airspace and no FAA Authorizations are needed…
Good Luck and Fly Safe…
Reactions: Rchawks
Yeah, those are all relievers. They're all pointed at the sky; transmitting to satellites require much larger dishes to narrow the aperture of the signal.
Yep, that nails it. We have friend that just moved in the building shown in your map on the edge. I've always wanted to fly from there, just haven't done it yet.
Reactions: LoudThunder
Yep, that nails it.
This is the TV Tower that does not show up on the Google Street Map, It was put in after the Satallite view was made… You have to go down to Street View to see it. It does not look like there are any cables that are attached to it. If you fly an Oval Video around it near the top, pointing the camera down at about 30 degree angle, it will make an interesting video…
But again, make sure that are no cables that you might "wander" into…
Fly Safe…
Reactions: Rchawks
Yep that's my POI, lol. I plan to take pics from a distance is all. Way to much activity and traffic to fly any auto missions for me.
Fly Safe…
THAT might interfere with your RC connection.
You should not have a problem. The DJI Drones communicate on 2.4 GHz and 5.8 GHz bands.
Television Stations in the USA broadcast on frequencies from about 54 to 806 MHz in the very high frequency (VHF) band, Other Networks listed below share this range of frequencies…
FM Radio broadcasts on frequencies from about 88 to 106 MHz
Aircraft broadcasts on frequencies from about 118 to 135 MHz
Ham Radio broadcasts on frequencies from about 144 to 148 MHz
Mobile or Marine broadcasts on frequencies from about 150 to 173 MHz
Cellular Telephone broadcasts on frequencies from about 806 to 902 MHz
Aliens from outer space broadcasts on frequencies from about 10 to 100 THz (Terahertz)
Star Fleet broadcasts on "sub-space B three nine". (Sub-Space -- 183k FTL*)
*183k FTL is 183,000 times Faster Than Light-Speed (FTL)
So, as Spock might say if he flew drones, "Live Long and Fly Safe…"
Reactions: Rchawks
100% correct regarding frequencies, @LoudThunder 👍
Also must consider transmit power, and how leakage and other issues in the electronics in the drone might be affected.
A 50kW transmitter on TV broadcast frequencies can create enough noise in the receiver amp section to overwhelm the comparatively weak signal from your RC at the drone's location.
This is why DJI recommends staying away from commercial broadcast towers. A high power signal at any frequency (typically used, not talking about Gamma Rays or something😁) can cause interference to electronics. How much can be tolerated is a matter of design and shielding.
Every receiver can be jammed by strong enough EM radiation at any frequency. Every trace on a PCB is an antenna. Enough RF power will result in voltages on those traces that gets rectified by the active circuitry, and interferes with the intended signals in the circuitry.
explorjus
