Display Radar Map
jmorse62
For some reason the display radar map option is not available for me anymore. Anyone know why, or have the same problem?1493086705427.png
No but people have had other menu options disappear. Make a note of your current settings then delete the App, reboot the device and reinstall the App. That typically works.
Rob
For some reason the display radar map option is not available for me anymore. Anyone know why, or have the same problem?View attachment 11535
I could be wrong but the "display radar" is at default ON (enabled) position only whilst "Obstacle avoidance" (the option above the radar) is enabled. This is necessary when u fly in OA.
If u where to turn OA off then the radar toggle becomes active and you can turn it off.
Also the OA function in low light will not work, so if you are in low light and want your radar on switch off the OA.
gomezstatiq
