DJI AIR 3 RC 2 Screen Recording Not Recording!
danCER
Hi.
I have successfully captured screen recordings with the DJI RC 2 since getting the Air 3. I know it is first recorded to the internal SD then you have to MOVE it to the external SD card.
Today, during a short flight, I went to the capture menu, hit screen recording, and waited for the recording indicator to appear.
I did what I needed to do, then hit stop. I powered off the Air 3 and then the RC 2 as usual.
When I went to MOVE my screen recording it was not saved in the internal Movies folder as normal. It wasn't saved anywhere.
Later I tried again but it failed to screen record.
I just did a firmware update and hope this fixes the problem.
ANyone else experience this?
Thanks for any thoughts.
You’re sure the recording wasn’t in the SD? If you have an SD card in the RC2 and you set the storage to the SD card, it will store all screen recordings directly on the SD. If SD card is set at the default storage, there’s no need to move them from the internal storage to the card.
utahloanrelief
