DJI Assistant 2 not working
mini2flyer
SD
I have tried everything I know of to get DJI assistant 2 to work on my Mac. It’s like the ports on the computer get no input. Can anyone help?
And you are using the correct version of DJI Assistant 2? There are several different versions for different drone models.
Go here ---> DJI Assistant 2 (Consumer Drones Series) - Download Center - DJI and there in the left column chose the one that is compatible with the drone you have (they list compatible equipment for each version in the bottom of each page).
Also, some of the versions for the older equipment aren't fully compatible with the latest macOS versions...
Reactions: Cafguy
I tried to get the consumer drone series but I have the latest version of macOS so is there no solution or workaround?
I have had issues on my Macs before It should work fine BUT I just use a windows machine with assistant 2.
Reactions: slup
You haven't mentioned which drone you have...
If it's any of the models the "Consumer drones series" support & you still can't get it to work on your mac--> then as mentioned, borrow a windows machine.
And it's equal if you have an older drone model that require a Assistant 2 version that doesn't support the latest macOS
--> borrow a windows machine.
FPV drone with DJI O3. I guess I’ll see if I can find a windows to use
They are right above and my new Mac Book Air gave a grunt and said no go. Luckily I have not disposed of my laptop and loaded it perfectly. The laptop is 12 years old!
So I borrowed a older windows and I still can’t get the software to recognize when I plug the drone in
And you power the drone on, right? Otherwise it will not work...
And you're sure that the cable you use is a data cable & not only one for charging..?
I'm having the same problem. I got a Mini 4 Pro for Christmas. I was able to connect to my Mac in January with DJI Assistant 2 and I just tried again yesterday and got nothing. Deleted and reloaded the software (I'm using the right version), tried different cables and connection types, got nothing. It's like my computer doesn't even see it as the photos don't show up on the desktop like they should. It does connect to my iPad with DJI Fly but I'd really like to be able to use Assistant 2. Anyone have any ideas on how to connect again?
Nevermind, after trying everything I could think of to get it working without success I just tried it one last time and now it's working. Have no idea why I'm good to go again.
CMDR DV TEARDROP
