Dji cable didn’t work I found a really short Micro usb and it workedThe DJI cable should work. Are you sure you weren't using a charge only Micro USB cable?
So trying to use dji assistant will not help with a compass issue because i cant downgrade?As of right now, there is no way to downgrade the firmware (or factory reset it).
I pressed factory reset yesterday with the drone connected to it and reset the drone according to the computer.The only thing you could do is reinstall your current firmware.
No, I ended up having to send my drone into djiso did it reload version 1.04.01 ??
