- Joined
- Jul 9, 2018
- Messages
- 7
- Reactions
- 7
- Age
- 57
I have the same issue. Just showed up after the latest Windows update. Running Windows 10 Pro x64 Version 1809 Build 17763.348. I have turned off ALL antivirus software AND driver signing verification as well as Windows firewall on both Public and Private networks. I uninstalled the program and scrubbed the Registry from all DJI references (I do not recommend doing this unless you know what you are doing) Still get the notification. I contacted DJI support and am awaiting a response. I would love to hear if anyone has a solution, $1500 for a drone I can't update is not acceptable!Anybody else having this problem on Windows 10?View attachment 65826
No solution yet. It's upon DJI's part to fix the issue.I would love to hear if anyone has a solution
Hi Thomas going all way to system but the dialog box that you said with#1 I dont see it.Here’s what BDOG said would work. It’s in anther thread. He did this on his machine. He deserves all the credit.
Windows registry to allow the download and subsequent program usage to work.
You will need to access this and change it as follows:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
and change the value EnableLUA to 0.
To understand how to change this value, do the following:
Click Start, and then click Run.
In the Open box, type %systemroot%\syswow64\regedit and then click OK.
OR
hit the Windows key and "paste" this: %systemroot%\syswow64\regedit by hitting "ctrl V" after copying the above bold text.
Once you have entered the registry, click on: HKEY_LOCAL_MACHINE then SOFTWARE then Microsoft then Windows then CurrentVersion then Policies then System
Next, you will see a dialog box with a #1. Change this to 0 and exit. Next, you will need to restart your PC for the changes to take effect.
Then, go the DJI site, download the Assistant 2 program again, and you should be able to use the program after a successful install.
Hopefully DJI gets this sorted out soon. Sounds like a recent Windows update may have triggered this.
Good luck.
Hopefully BDOG will reply.Hi Thomas going all way to system but the dialog box that you said with#1 I dont see it.
Cmon guys. This has been fixed days ago. Download the latest and it should work without issue
