DJI Assistant - Verification Code
Jon6565
I have a Macbook and I am trying to log in to DJI Assistant. It asks for my email and password but also a "Verification Code". I don't have one. Is DJI Assistant only available with the care program for $$?
If not, where do I find it?
Thanks
Are you connected to the internet? The "verification code" is a simple CAPTCHA image that should appear next to the related field, but can't load with no connection.
OMG! I cannot believe I didn't see that! Normally the text says "enter captcha" or something... I assumed a provided code!
Such a dork. :confused:
Thanks Kilrah
If you are using a Mac, sometimes the OS does not let the CAPTCHA code appear. Put in any random code. Let it say that the code doesn't work and then the next code appears.
Reactions: Drün
I'm using HP laptop...no go with verification code...little box with x, but no capture code...entered the same 4 digit code I used when logging in and it was invalid...and no capture code appeared....am I doing something wrong?
i had the same issue,i deleted and reinstalled the app
CTD
