I have an old phone I use just for my mini, that runs the Fly app when I fly. I also have a regular phone where I have also installed the Fly app. Is there any way to get the flight records from the old phone to appear on my regular phone?
That's the problem, it isn't. There's 5 months of flight logs sync'd to DJI off the old phone that aren't showing on my latest phone.log into the app on both phone and be sure internet is available. Data will be sync’d over the cloud.
I believe once the app syncs the logs to DJI, some data is deleted off the phone. I can see the logs in airdata but I was hoping the DJI sync would be 2-way.Blue tooth them across perhaps? I used bluetooth to copy them to my laptop but that was when my laptop couldn't see the phone via a USB cable. I have fixed the latter and now just copy them via USB cable.
PS I don't like uploading stuff to the cloud.
You should be uploading ALL your flights into AirData. That way you will have a permanent record no matter what drone you fly or phone you use. AirData will give you a "TOKEN" to use to make the connection. I upload at the end of each day. In AD, also, I manually enter flights with other applications (not available on the Fly app).I have an old phone I use just for my mini, that runs the Fly app when I fly. I also have a regular phone where I have also installed the Fly app. Is there any way to get the flight records from the old phone to appear on my regular phone?
I do upload to airdata but only after sync'ing the app folder contents to a OneDrive folder using a special app, not the OneDrive app. Then I enable sync in Fly and let it do it's stuffYou should be uploading ALL your flights into AirData. That way you will have a permanent record no matter what drone you fly or phone you use. AirData will give you a "TOKEN" to use to make the connection. I upload at the end of each day. In AD, also, I manually enter flights with other applications (not available on the Fly app).
