DJI GO 4 - Editor
peros550
Hi , I don't know if it has been asked before. I did a quick search with no luck.
I am using the Go 4 Editor to join various clips into a single video. As the video is cached in 720p the output version is the same. I know I can import the videos from the SD while the phone is connected to the controller which in turn is connected to the Mavic.
My question is if I import from the SD, the existing videos I have already edited will be updated with the higher resolution content or I have to edit again from the beginning?
Reactions: masnizar
No, it will not get updated as they are two seperate files. Best is to start from actual files (from SD card) if you are looking for higher resolution.
coldandbitter
