Dji goggles gimbal tracking issue
Viciam
Hi guys,
Whenever I use the gimbal tracking option in goggles, I always after have reset the gimbal position to centre via the touchpad because it doesnt stay centred to the mavics heading. Like it will stay 30 dgrees to the left or right and I have to reset it. What is the issue with this? Its annoying.
If you're using gimbal head tracking, you will need to turn your body back to original starting position to recentre the gimbal - there is a little white cross in centre of screen which shows you when you are centred, along with a degree indication of how high above or below centre position you are.
If you don't like the gimbal turning 30degrees left/right, turn off head tracking, or use the 'head tracking flight' mode instead of 'head tracking gimbal' mode. Then aircraft will yaw with head turning and you should still have view centred on aircraft heading.
cbooth
