DJI GS Pro Internal Storage
ajbajbajb
France
I have a well-loved Mavic Pro 2 which is showing recurring 'SD Card Not Initialized', 'No SD Card' issues.
I need to run some missions, is there any way I can use the internal storage? DJI Go Fly shows both options and everything is working. It's only in DJI GS Pro where I see all the SD Card issues.
If GO4 recognises the microSD's without a hitch, it sounds like the problem lies with the Ground Station software. Have you tried uninstalling it and then downloading a fresh copy?
You can use the internal storage for missions by ensuring that DJI GS Pro is configured to recognize it. In the app, select the internal storage option when setting up your mission. If the SD card errors persist in DJI GS Pro, check for software updates or try reformatting the SD card. You could also try using a different SD card or resetting the drone to resolve the issue. If the problem continues, contacting DJI support might be necessary.
explorjus
