DJI & Litchi
Davidwh
Burnley, Lancashire. NW England
Is there any issues with having both apps on the same device (android) and running then separately. if that is the case, then I take it that all the settings will have to entered for each app separately???
many thanks in advance
Only trivial issue I have found (android) is with the C1/C2 button settings. When switching back from Litchi to DJIGo they will get reset to unassigned. This is probably related to how Litchi can have multiple setting for each C button depending on which Litchi Flight mode you are in. All the other setting seem to stick between the apps as far as I can recall..
Just dont let your android set either app as the default when you plug in the USB lead. Otherwise you wont be able to launch the other app.
Always use the "just this once" option having chosen either Litchi or GO, when the pick box pops after pluging in the USB.
On a sidenote;
Until last weekend, I have been using my Nexus 5x android device in the controller of the mavic.
Before the .600 update, I was able to use both Litchi and DJI Go4, but after the update Litchi wouldn't connect anymore. Annoying as that may be, I bougth an iPad Mini 4 last weekend (YAY!!!), and I think I need to purchase Litchi for iOS then, or is there a way to prove that I bought it for Android already so that I don't have to pay double? And another question: will Litchi and DJI Go4 work side by side on iOS, even with the latest firm/softwares?
cbooth
