DJI Mavic mini 1 camera stuck. Touches bottom plastic piece. How do I fix it?
hugofrost
sweden
Pretty much what I wrote in title. It seems to be touching the plastic part under the gimbal. Is it something I can fix myself?
First have you checked that all 4 rubber grommet support/vibration damping legs are properly secured in the right position? Sounds like maybe one of the supports hidden up inside the under the front of the nose casing may not be in the right position. I'd start there. There are lot's of help videos on the camera removal that show the proper positioning.
Reactions: hiflyer201
Welcome to the forum from California!
The plastic piece you're referring to is not the gimbal cover is it? No I knew it wasn't :cool:
Reactions: EyesWideShut
Shemp
