DJI Mavic Mini 2 starting problem, strange ...
sky
when I press the power button and the drone motors and the drone itself starts to turn on, and after 1 second it turns off (the time the battery flashes) if I press it once briefly and then a second time and hold it, then the drone starts and fly as should... my question is.
why does the drone turn on when the button is pressed once?(shouldn't it run only in presed 2 times? ) shouldn't it just flash the white dots and stop without moving the motors?
this is after i change Flex Cable Of Esc To The Core Board Motherboard
Are you saying that the motors the gimbal and motors twitch on the FIRST press?
Perhaps you should post a video of what you are describing.
RetVetPJ
