Dji Mini 2 Fcc hack
What exactly does the fcc hack do for you?
It increases trasmission power between drone and remote controller. Increasing range/decreasing hiccups etc. In US that transmit power is on by default but in other countries it's limited. This hack unlocks it.
Reactions: Adee86
Any luck or did you pay the 25€ they want to activate FCC on the Mini 2 ?
Reactions: Harris
No cost you for licence
I went with the drone tweaks FCC App, i did not fancy messing with the drones firmware, have to fly Apps in iPhone, the standard app and the FCC version
It works fine on my mini2 with latest firmware. You have to do it first after switching on drone and rc but it takes just some seconds
You have to do it always after switching on drone and rc. You don't need fake gbs etc. It's just the procedure you see in the video
Not before every flight, after power on everything, maybe you fly twice or three times before power off.
If you prefer a permanent solution you must buy one, but so far I know works the Drone-Hacks solution with the Companion app in the same way.
tagir
