Great video. Thank you. While you not addressing what I consider to be a critical issue with the Mini2 you have proven the thesis of my point: The Mini 2 in the Cine mode need to be slowed down and the stick input/response modified, as with the Mavic 2 in the tripod mode because of the latency!
Until your post I hadn't had latency on my mind but will do so going forward. I practice indoors to get used to tight spaces and for potential projects in close quarters. It appears that latency awareness becomes more important when your drone suddenly shifts into Atti mode where it loses all stability aids.Thanks folks. I have had a lot of close calls, usually realized after the fact when I view the SD card video. Now latency it is always on my mind when flying close to objects and I try to plane ahead a bit.
Same here, it just answered the questions bogging the mind....thanks fir sharing.Thanks folks. I have had a lot of close calls, usually realized after the fact when I view the SD card video. Now latency it is always on my mind when flying close to objects and I try to plane ahead a bit.
