DJI Mini 4 Pro NFZ hack
I was reading somewhere that there is allegedly a set of parameter changes you can make on dronehacks that will disable nfz's as well. Has anyone heard of this?
Do you have any additional information like where did you hear it? So i could do some research.
EDIT: I believe it's done by rooting and deleting the NFZ database, but I could find no recent information on how to delete the databse.
Search for sincoder fcc hack. If you have compatible firmware on RC, it enables some hacks like fcc mode, drone leds off and some others and leaves adb port open. But for some time he is not responding on telegram.
I haven't found his information yet. I want to enable ADB so I can research more about installing 3rd party applications for RC 2.
Sincoder, djircfcc, djifcc, fccmod - these coders have access to DJI keys and can unlock MANY things DH and DT can't. need I go on? 😏
Sincoder did a great job yesteryear but it's also mainly just FCC item mods. NFZ/Alt hacks are very different and requires a lot more coding.
I have been working on trying to do this using DH ADB Root software license. I am having connectivity issues with the mini 4 pro when trying to enable ADB via DH If anyone has information on how to do this, I am trying to remove the nfz restrictions.
I turned off the gps stuff in parameters but it then capped height so I opened it up wrapped the whole board in tinfoil and it could fly anywhere but couldnt keep itself hovering very stable like you needed to keep an eye on it.
to launch u had to change the parameter start without gps value
I thought that DJI had dropped the requirement to unlock flights in NFZ’s and put the onus on the pilot (where it always should have been) to fly safe and legally? I know this is a uk/european article but it was announced for Trumpland first.
Yes they have in the UK, i tested my Mini 4 at the airport, no i didnt fly i just started the motors
No members online now.
0x6e08715
