DJI RC Pro in FCC mode with C1 certified Air 2s
sema2022
I live in Norway (CE) and my RC Pro controller is FCC enabled with Drone-Hacks to get more stable transmissions (not more range). I have both stock N1 and RC Pro controllers.
It would like to C1 certify my Air 2s drone with the stock controller and swap to RC Pro/FCC in noisy or obstructed areas.
Does anybody know if it is possible to use the RC Pro controller with the newest FCC hacking capable firmware (v03.02.0200) connected to an Air 2s with the new firmware required to be C1 certified?
I suspect that RC pro must be upgraded to v03.02.0700 to be able to connect to the C1 cert. Air 2s. If I upgrade Air 2s to test, I may not be able to downgrade if the FCC mode is broken. For me are currently FCC more important than C1.
Bump - is there anybody with similar setting in a EU/CE country planning to upgrade to C1 firmware without losing FCC mode?
I have contacted DH, but they could not confirm it will work/have not tested it.
twin01
