DJI Simulator Software
JMagnus
Minneapolis, Minnesota
Are there any plans to make this software compatible with Apple OS? As a new drone pilot located in a cold, wintry area of the country I would like to practice flying my drone in the winter. I can't imagine I'm the only who feels this way. However, I only use Apple products. Thanks.
I've been waiting, but no word.
I looked into it a little, and discovered it's intended for companies to train employee pilots so as to learn to do inspections without wrecking the drone.
If I read it right, the price tag is $1,350, so I'm out
The controller for my Mavic Pro Platinum will run the DJI app on my iPad when it is plugged in and connected to the actual drone. I realize this is not the same as the program on a desktop, however it is more realistic in the sense that it uses the controller joysticks and has the proper settings and readouts as an actual flight, including the battery time and controller buttons. The adjustments to the controller will alter the flight characteristics in the sim as well as the real drone.
Edited to add: If you choose to do this, remember to remove the props from your drone. I suspect they may be active, in sim mode but I'm not sure.
Well, you may be correct. There's a free version so I thought perhaps that would give limited use for non corporate purposes but I could very well be wrong.
This sounds interesting but if the drone isn't flying how does this work? Is it a demo mode or something?
I should've been more specific. It is a simulation of flight with your drone, but it does use the actual controller via the DJI software. It realistically simulates flying your drone.
Reactions: JMagnus
Hello JMagnus !
You are an Apple fan, OK ?
If you are talking about the DJI Flight Simulator, the one used to educate Phantom pilots for professional
shooting, you need a computer running Windows 10 (or possibly some older MS OS).
If you by any chance have got an IMAC, you can install Windows 10 on it.
Apple has detailed instructions on how to do that.
It might be possible to use a MACBook also, you have to research !
Possibly IPad, I have no idea if you can multi boot it.
I installed Win 10, latest version, om my IMAC 21.5" with Mojave 10.14.2, and then the simulator.
You need to check the requirements, a few controllers are not supported.
I have an Mavic Pro, so I have problems (for now anyway).
My reason for doing the install, is that I do not have a sufficient powerful Windows machine.
Good Luck !
Reactions: JMagnus
Hello JMagnus !
Good Luck !
Thank you!
RichardThiery
