Do this screwdriver set contain the correct pieces needed to unscrew the screws of the Mavic pro and remote?
Hyper Tough 44 Piece Precision Multi-type Screwdriver Bits Set TS99913A - Walmart.com
In found it on the Walmart websites it's actually at my local walmart
I'm curious as to why you'd want to unscrew it but yes, it should. However, I would recommend also purchasing a set with long points because some of the screws (at least on the Mavic 2 Pro/Zoom, Mini 2, and Air 2) are somewhat far into the body and those tips won't reach. I know this because I have that exact set, all three actually. But yes, it should work for most screws.
Reactions: TheSnowyPilot
Also the gimbal screws
Only for repairs. A ribbon cable needs to be replaced.
Well, that should be sufficient. I've never worked on a Mavic Pro so I don't really know but with the Mavic 2 Pro, it'd definitely be enough. However, if you don't want to risk any delays, I'd also buy a set with long points. Like this:
For a Mavic 2 Pro you will need H1.5 that is a hex head not a torx head.
For the screws you will need PH00X2 and/or PH000X2.
The PH000X2 is smaller than PH00X2.
I think the smaller ones were for the ribbon clamp to the gimbal circuit board. (which on one of my drones were extremely tight.) but mostly just PH00X2 and the H1.5.
The set linked to above is No Good because there is no HEX only torx type.
Jo_Neu
