Thanks Greg. I have heard diff. opinions on how to install Litchi on the CS (including having to run a usb cable between two ports. Can you explain how you did it or point me in the right direction? Thanks again.Hi
#1. Yes you can install AirMap
On CS
#2. Did not try to use AirMap for
Flying my drone
I use AirMap only for checking
Restriction zones, but if you want to compare AirMap and Go4
Go4 is more advanced
If you want use some other app
I can recommend Litchi
Good luck
I use a tripod with my 7.85 CrystalSky and the adapter plate partially blocks the USB-c port on the bottom of the monitor. I use the micro USB port on the side to connect the CS to the remote. Don't know if the 5.5 CS has the same port locations.
