Downgrade firmware version on DJI Mini 2 SE to V01.00.0360
SamC
Sydney
Hi,
I've currently got a DJI Mini 2 SE running the firmware version 01.00.0410 and I'd like to downgrade the firmware to V01.00.0360. I've tried using the DJI Assistant 2 and Drone Hacks v1.47 to achieve this. That firmware version doesn't appear to be an option on DJI A2 and I am running into the below error when I use the DH v1.47 tool.
Would anyone know how to work around this error or another option I can look at to downgrade to V01.00.0360. I'm happy to pay for this service if that is available as well.
Thanks in advance!
If the ARB is identical and DH gives an error then raise a ticket, there is a LOG file located at C:\Users\yourname\.dronehacks which may be of use to them, i would clear them out then redownload DH again and put it on your desktop, then download the firmware again and then try, this will produce a clean log file
You could also try reflashing your current FW to see if that cures the issue. although im confused as to why you would want to downgrade to a lower FW, is there a reason for it
if the firmware version you are using is the version that enabled RID then You cannot "rollback" the firmware.
The first thing I would try really is post number 2.
If that is correct then its news to me, is there documentation that shows this?
Its the LAW. even in your country. rolling back firmware in order to defeat or avoid RID is a crime. DJI has placed measures in the firmware to make this impossible thru the DJI assistant.
I have dropped you a PM as i dont want to discuss this here
Reactions: Cafguy
Hi, Guys
I'm try to downgrade firmware my DJI Mini 3 Basic with this software, but the progress stuck on picture
and not see green bar progress
please help
Hi everyone, same error, any solution or news?
Hi,
Thanks in advance!
gimfbsx
