EMMC FULL
ddean0419
I can't find any info on this error message. I can no longer shoot video. What is the EMMC and how do I empty it and keep it from filling up?
could be external mavic memory card or even the internal one dont have a mavic 2 so only a guess
It’s an assumption/guess (on my part)- given EMMC in this context would ordinarily mean embedded multi media card it might be, as has been suggested, indicating the internal (soldered to the board) flash storage is full.
Good chance installing an SD card with space and/or formatting the on drone storage will clear this error.
Reactions: old man mavic
That could indeed be referring to the internal 8GB storage. EMMC is flash memory and controller on a chip.
8GB isn't very much and will fill up fast, especially in 4K. In 4K that gets you probably about 13 minutes record time.
Do you have a U3 rated SD card installed? If so, did you select to use the SD instead of the internal storage in the app?
To get the contents of the internal storage, you'll need to connect your AC to your PC while AC is powered on. You may also need to install Assistant in order to install the needed driver, even if it is probably presenting itself as typical USB mass storage.
Reactions: Gindra
Robby1983
