ESC error and Brushless Motor Coil Repaired
jftman
western NY
I have a ESC error, can’t take off.
I just received it as a damaged untested drone.
There was a small stone in tge front right motor. Before clearing the coils I had not powered it on to check status with controller.
I found a wire severed on a coil and I superglued it then applied some conductive paint on the area.
I powered up the drone and found the ESC error, it does not have a number also.
Is the coil repair not a good repair? Does this motor condition throw an ESC error? Is the wire insulated that is the coil? I would believe per the pic attached that if insulated the conductive paint could be messing with the ohms of the coil since it crosses several courses.IMG_6994.jpeg
Been following your trips down fix-it lane for a while now. Got to admit... I'm impressed with your singlemindedness, but most of what you're trying is very Heath-Robinson.
The one thing I do know is that drone components are precision parts that make up the airframe of a flying vehicle that weighs the best part of a kilogram (mav 2 zoom: 905grms). If the motor's shot: a bit of glue and conductive paint won't cut the mustard. Buy a new(er) motor and replace like for like... you might end up with a working drone that is actually safe to fly.
Best to swap the motor. Repair won’t be safe in the air.
If that's the Mavic pro 2 you have been working on......an arm With motor, is 40 bucks. just sayin.
I had never heard of Heath-Robinson. You made my day and I agree. Hind sight is wonderful as your drone sits in pieces on the ground.
Reactions: Felix le Chat
I have a ESC error, can’t take off...
There was a small stone in the front right motor...
Even if you change the motor you may see that the ESC error remains... with a stone in the motor making that coil damage it's possible the ESC burned up. Forcing a rotating electrical motor to dead halt usually cause other components to give up.
Yepper. I did receive an arm with motor.
I Hope the damaged motor is causing the error.
Good chance? I don't know if the motor ever seized.
Are ESC a component part or I must buy a main board?
Reactions: Cafguy
The ESC on the mavic 2 series is a separate component. Your motor is most likely the culprit. I would change the arm first and see what that does.
Reactions: jftman
Getting set to install motor as soon as heat shrink tubing arrives.
Doing it without opening the drone.
Update, tubing arrived, I spiced in the motor and all errors cleared up. ESC normal. Props spin and can take off.
Marlin
