The SC already has a microphone. Why would you need another one, even if it were possible?Is it possible to use a external Microphone pluged into the USB-A Port 20 on the Smart Controller ?
Was thinking of filming a train passing by. so wanted a external mic close to the tracks.The SC already has a microphone. Why would you need another one, even if it were possible?
yes it does, But pick-up needs to be a little closer some timesI thought it had a microphone already. I don't use it.
its conceptual right now. we are trying to sync the vid to the sound and stay safe.i know this is kind of **** ,but it could have some really cool applications.Do you actually use it? What is the workflow for getting it to your video.
So your talking about transmitting the audio from the tracks to the controller? That won't be recorded with the drone's video. Just record at the tracks with a portable recorder. This is not hard to sync with drone's video in post. It's not like dialog, even easier.Was thinking of filming a train passing by. so wanted a external mic close to the tracks.
Or if you are close enough, why not use your cell phone and then merge the video and audio when editing.So your talking about transmitting the audio from the tracks to the controller? That won't be recorded with the drone's video. Just record at the tracks with a portable recorder. This is not hard to sync with drone's video in post. It's not like dialog, even easier.
I did notice when I was trying out Parrot to record sound that I had to up the "gain" or whatever otherwise the sound was really anemic.yes it does, But pick-up needs to be a little closer some times![]()
