The fcc hack i am trying to use keep coming up that its got malware and wont unzip the exe file has anyone else had these issues.Its the permanent one which is $69.
he bought the permanent fcc hack, which is not an .apk fileThere is no .exe file, it is an android app (.apk). What are you trying to use?
My dji rc enable fcc only needs 36usd , do yours needs 69usd?The fcc hack i am trying to use keep coming up that its got malware and wont unzip the exe file has anyone else had these issues.Its the permanent one which is $69.
The one I used from Sincoder did come up with a malware warning in a routine scan, however it works just fine & my PC hasn't spontaneously combusted yet, so I just assumed it was because the apk is an "unknown source"I might try another unzip app. It think it will just be the same outcome.Why on earth would the person include malware is beyond me .I presume that somefolks on here got the same exe from Sincoder could they have a look and see if it is named DJIRCFCCZIP.7z and did you scan it for malwear ?
mine was only $0. hehe. ive got NLD, but DJI will not allow to downgrade firmware on my mavic air2. that sux, seems no one has hacked it yet.The one I used from Sincoder did come up with a malware warning in a routine scan, however it works just fine & my PC hasn't spontaneously combusted yet, so I just assumed it was because the apk is an "unknown source"
It was only 40 dollars too....
How to get it free?mine was only $0. hehe. ive got NLD, but DJI will not allow to downgrade firmware on my mavic air2. that sux, seems no one has hacked it yet.
Did you look at DRONE-HACKS.COM? The license for a Mavic 2 is about £40 and you have a good selection to choose to install, including CE-FCC hack and FCC BOOST which gives a signal that is about 30db as opposed to the stock FCC signal which tops out at 26db.The fcc hack i am trying to use keep coming up that its got malware and wont unzip the exe file has anyone else had these issues.Its the permanent one which is $69.
Where?also id like to add, you DONT NEED TO PAY FOR THIS,.ITS AVILABLE FOR FREE!!!
