FCC mode with the Mavic Pro
PeteS2017
Apparently, getting the Mavic Air into FCC mode (to get increased range) if you're outside the USA is easy: you just use an app like Fake GPS to trick your phone or tablet into thinking it's in the USA.
But that's with the Mavic, which uses WiFi. With the Pro, which uses Occusync, do you have to use a different method in order to get it into FCC mode?
I might get in trouble here but you can put a modded version of dji GO and a modded firmware on the MP to get it into FCC Boost mode. This increases the output past FCC mode. Send me a PM if you want the link
Im new to Mavic Pro, and I have poor range, so I try get it into FCC mode using fake-gps. Anyone have a guide that work?
Fake gps will not work with mav pro. You need modified firmware
Look up nolimitdronez
If you do manage to get into FCC mode with a suitable firmware will it stay in that mode if you move back to current firmware ?
I don't believe so. But Im not an expert in this area.
CMDR DV TEARDROP
