Field Chargers Recommendations
HarmonyWound
Hi,
I am new to this but I was wondering what is the best way and what do i require to charge the Mavic Air batteries in the field, I would like to use the portable 30000 mah usb portable power pack if I could.
Thank you
What do you mean by "in the field"?
If you're near a car, the cheap 12volt to 120 volt cigarette lighter power adapters do the job. If you are talking about a remote area where no power is available I would take as many flight batteries that you need rather screw around with another portable battery. I haven't used more than the three than came with my Air in a single session away from my car.
A Smatree DP160, it can charge upto 5 to 6 batteries with 3 charging simultaneously. It also has a usb output for the controller
viliuss23
